CapriRacer
Jul 23, 2013Explorer II
Just an FYI,
There's a provision that isn't well publicized about ST tires (LT tires, too) that you can over-inflate them 10 psi and that allows you to run up to 75 mph. If you also reduce the load by 10%, then you can run up to 85 mph.
So, yes, it is permissible to exceed the inflation pressure written on the sidewall - but only by 10 psi.
Looking for advice before your next adventure? Look no further.25,202 PostsLatest Activity: Jul 21, 2026
