JIMNLIN
Jul 23, 2013Explorer III
Before pumping those tires above sidewall max pressures talk with your tire dealer first about warranty issues. Pump a tire above its pressure rating and blow the sidewall out or split the tread belts and a dealer is under no obligation to honor the warranty.
Increasing pressure in ST tires for higher speed operation has changed over the years. Goodyear tire spec sheets at one time recommended that only certain sizes of their ST tires could do this however they were required to have a reduction in load with those higher pressures and speed. I see that information has changed.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
