wny_pat1
Jul 23, 2013Explorer II
full_mosey wrote:FastEagle wrote:Think
The correct answer is to use the recommended air pressure value found on the tire placard.
FastEagle
Footnote: If the inflation pressure corresponds to the actual tire load according to the tire manufacturer’s load and pressure table, the tire will be running at 100% of its rated load at that pressure. This practice may not provide sufficient safety margin. Any air pressure loss below the minimum required to carry the load can result in eventual tire failure. (Toyo RV tires)
Aren't you saying that the only approved way to travel with ST tires is to stay under 65mph?
The TT tire placard says NOTHING about speed. Why can't I drive any legal speed?
HTH;
John
You guys are mixing apples and oranges here!!! Toyo only makes commercial trailer tires, nothing smaller than 17.5". They are not a ST tire, but a "Trailer Position" catagory tire listed under their Medium Commercial Truck tires.
And both commercial trailer tires and ST tires have speed ratings. Just look at the tire specs!
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
