jadatis
Jul 24, 2013Explorer
full_mosey wrote:CapriRacer wrote:
Just an FYI,
There's a provision that isn't well publicized about ST tires (LT tires, too) that you can over-inflate them 10 psi and that allows you to run up to 75 mph. If you also reduce the load by 10%, then you can run up to 85 mph.
So, yes, it is permissible to exceed the inflation pressure written on the sidewall - but only by 10 psi.
Can you do the math for me?
I have a single axle with ST175/80R13 50psi 1360lb rated tires. My heaviest wheel is 1060lbs. I run the psi from 45-50 now.
What pressure would allow me to travel at 65-75mph?
HTH;
John
Strange thing of your ST tires is that mostly they are allowed to carry more load because they may deflect more at lower speed, and this gives higher maximum load at the same reference-pressure ( that 50 psi , wich is not the maximum pressure) , then for a LT tire with same sises.
But searched with google for LT tire with same sises and 50 psi , and could not find.
Only found European 6pr tire wich needs 55psi in that system with load index 94 and speedcode P wich is up to 150km/90m/h.
If you calculate that back , to the 50 psi and 1360 , you come to the same load to carry. So probably your ST tire has not that extra load to carry as for most ST tires is done for more deflection at lower speed. They did not use this extra at your tires , and this makes them better then most ST tires, so positive.
Both tires filled in in my Traveltrailertirepressurecalculator, give and advice of 43 psi for your ST and 44 for the Falken 175/80R13 94P.
This is already with reserve for things like , pressure-loss in time, unequall loading R/L, little misjudging of load and misreading of pressure and load-scales.
So if your loads are weighed , and you are sertain that you never go over that load you gave, for savety you could add the 10% to the pressure for higher speed and better handling, but will come to max 48.5 psi wich is still under the reference-pressure , and you dont have to use the 10 psi extra above that wich is allowed. With the TT loaded to 2400 lbs and tonge-weight of 10% so 240 leaves 2160 axle load /2=1080 lbs per tire. Then a weightdifference of 240 lbs L/R possible before one tire reaches the damage border at higher speed.
So endconclusion, if the data you gave where right , you dont have to use 60 psi pressure , these tires have all the reserves at 50 psi.
You probably never had any problems with these tires, and that would prove your 45 psi used is ok. But correct me if I am wrong.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Feb 11, 2018
