nevadanick's avatar
nevadanick
Tire speed ratings
Only thing i can find about Maxxis M8008 is that its Speed rating is R which is 106mph. Good to go :)
  • JaxDad's avatar
    JaxDad
    Explorer III
    boondockdad wrote:
    ST tires have a 65mph rating
    GoodYear has a qualifier on their website having something to do with loads and higher inflation that supposedly increases the speed rating to 75... for what that's worth.
    I wouldn't run ST tires if you paid me. Garbage. Regardless the manufacturer.
    What if someone has a modern lightweight unit that sits on 13" oor 14" tires?
    Surely you wouldn't be advocating they run P-rated radials on them?
  • ST tires have a 65mph rating
  • Are you sure you aren't looking at the "Load Range" rather than speed rating?
  • The majority of the RVing population doesn't even know that all tires have a speed rating
  • Carlisle Radial Trail RH Trailer in the size I use (235-80R16) have a speed rating of "L" ie 75 mph
  • On Maxxis website it just says high speed radial. I found the R rating in an add for them. I have never looked at mine.
  • Unless Maxxis has completely redesigned the M8008's????
    Mine are rated for 65mph.
    I have LR-E. Good tires.
    Everything I have seen regarding the Maxis' 8008's is that they have a max speed rating of 65 as do most, not all, of the ST's out there. Either way my experience is that the Maxis' represent the best of ST tires. My max towing speed is 60 so it doesn't mater in my case.
    :C
Looking for advice before your next adventure? Look no further.25,164 PostsLatest Activity: Sep 18, 2025
