calewjohnson's avatar
calewjohnson
Tires again....
Good evening,
Currently at a campsite with some limited internet (Tengo internet)...so my searching has been meek at best.
I have a Voltage 3950. Made it to our Thanksgiving camp site....while doing a post trip walk around, I noticed one of the tires has developed a bubble in the sidewall. Heading into town tomorrow to price some tires....
I had Kumho 857 on my last trailer, awesome tire, but not in my size now... I have ST235/80R16 on this trailer (I have been told the factory rims are good for 110 psi, but I would rather stay at the 80 psi currently). I was leaning towards Maxxis, but ran across a post that said there were better options for a 16 inch tire. I have received tire advice from JIMNLIN and JJBIRISH in the past, hopefully they can chime in with some good info.
I should also add, I am a three axle, six tire trailer....with a 20k max weight...right now we are 18.5k, give or take with holding tanks.
Thanks in advance...sorry, I know tires are a touchy subject, but I am in a pickle....would like to do this only once.
Cale
  • There will probably be a weight rating stamped on your rims, which has nothing to do with PSI rating.
    If you have any confidence in the tire store, talk to them about air pressure. Underinflating lessons the tires ability to carry the load and creates heat, which is bad for tire life.
    Good luck.
  • I assume you have a spare and if so would put it on no matter what the tire store said.
    Peace of mind.
    Safe travels.
    I'm guessing the 20k lb tri axle trailer has 6k axles which the Michelin XPS Ribs or the Bridgestone R-250 both being a all steel ply carcass commercial grade LT tire would be a best choice on that big tri axle.
    There are also some lower priced very good fabric ply LT E tires @ 3042 lb capacity.
    If the trailer has 7k axle then the Goodyear G614 RST or the Sailun S637 both being a load range G tire at 3750 lb capacity is a good choice if staying with a 16" tires and wheels. The G614 RST is made for the "Regional Service Trailer" industry. The Sailun S637 is another 16" all steel ply carcass commercial grade tire.
    Both of these tire require a 110 psi rated wheel if you want the full advantage of the higher rated 3750 lb tire capacity.
    And of course the 17.5" wheels and tires for 7k axles is another option. However I'm not a fan of over tiring a tire on a trailer to the point of derating its max performance and reliability.
    I sure wouldn't use a ST tire on a trailer that size.
    Sir,
    Thanks for the info....because I had to make a decision today (Thanksgiving kind of messes my timeline up) and the tires will be replaced at a shop on the way home this Sunday, I opted for the Maxxis. The shop was able to get me the ST235/80R16 Maxxis for $1100 out the door (mounted, balanced, and tax). I could not touch that anywhere. While these are being installed, I will be checking to see what pressure the wheels are rated. I will also be doing some measuring to see if an 85 profile tire will sit in the wheel well
    Seeing that this fiasco is has pushed my timeline for tires, I will be getting the trailer packed for our Christmas trip. This will be when I get a good weight that will tell me what my "camping weight" will be. I have held off since we have not quite put everything back after our trade. I do know I am under my trucks CCC (14k GVWR) and I am under the CCC of this new trailer (it has nearly four times as much as the old one), hence my slowness to get an actual weight.
    My only scare right now will be the 50 mile drive to the shop with (what I perceive) a small goose egg in the side wall. I explained it to the tire shop and they said it would be fine, it sounded like I scuffed a curb... After paying so much for this rig, I don't want the thing damaged so soon.
    Thanks again. I will report back when I get the wheel ratings Sunday.
    Cale
  • I should also add, I am a three axle, six tire trailer....with a 20k max weight...right now we are 18.5k, give or take with holding tanks.
  • Oh boy here we go-I put Carlisle tires on my trailer.Weights a little over 15000 lbs.Went with 285/80r/16 load range F,3900 lb rating @90 psi.Good so far woth about 2000 miles on them.Works well for me,sure others will not think so.
  • Thanks...the problem with the LT tires around my size...they have a max load of 3042 lbs. I need something closer to 3400 lbs. The current brand tire I have, the tire dealer says they are popular for commercial around here. He mentioned Hercules ($1100 out the door). I am going to get a price on Maxxis today. Not knowing what the psi rating on my wheels right now is hindering the process...
    Cale
  • bridgestone duravis R250 is a made in the USA tire and I just put them on the MH, seems to be really nice tire. Not as much as the Mic's
  • If you only want to do it once, the michelin xps rib or bridgestone duravis R250 is your tire.
  • B.F Goodrich Commercial TA or other U.S Made Load range E Light Truck tire with a NON-aggressive tread pattern in size 245/75R16 will give you load rating of 3024 pounds per tire. Six tires is 18K plus so with a 15 to 20 percent pin weight you are plenty good. About $170 each plus whatever the dealer tacks on.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 18, 2026
