- RinconVTRExplorerAll rubber tires and/or tubes lose air constantly, but very slowly. ALL.
Long term inactivity is the worst possible thing for mounted tires. Read up on OEM's recommending airing up 25%-ish over max cold for long term storage. It helps prevent permanent flat spots. - Water-BugExplorer IINo tubless tire makes a perfect seal with a rim. Same goes with valve stems. If it really troubles you, install tubes.
- kvangilExplorerMy experience has been that it depends on how long it's been sitting in storage. If just a couple weeks, I barely lose anything...Over winter, it may drop about 10psi.
- darsbenExplorer IIThey will lose air sitting and they will show less pressure on a cold day versus a warm day.
- TerryallanExplorer IIMine don't lose that much. But they do lose some sitting around. And don't fall for that nitrogen thing. Mine came filled with Nitrogen. They still lost air waiting on the next trip.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
