- Jim_ShoeExplorerCheck out Tire Rack. If it rolls, they have the tires for it. And they ship to you, or to a dealer of your choice for installation. My daily driver is a 4WD pickup truck, which doesn't do well on snow. I ordered 4 Bridgestone Blizzac snow tires. They arrived in just a few days, mounted, inflated and delivered onto my back porch. I'm currently looking for a glass mountain to climb. :)
- LowsuvExplorerThere is no reason to believe that Carlisle are inferior tires .
Increasing the Weight rating in pounds as posted on the sidewall is more important than brand .
There is a good solution that uses your current 15 inch wheels , that will fit your wheel wells :
There are at least 2 different LT graded tires in a 225/70 R15 size that can be fitted to your current wheels .
Neither are made in china.
Recent discussions on this forum have shown that LT tires are graded using a tougher standard .
Goodyear Cargo G26 rated 2470 # , made in germany and france.
Continental Vanco 2 rated 2470#, made in germany and slovokia .
I ordered continentals from tire rack on a monday and they were delivered by wednesday recently .
Goodyear G26:
http://www.tirerack.com/tires/tires.jsp?tireMake=Goodyear&tireModel=Cargo+G26&partnum=27R5G26&vehicleSearch=false&fromCompare1=yes&tab=Specs
Continental Vanco 2 :
http://www.tirerack.com/tires/tires.jsptireMake=Continental&tireModel=Vanco+2&partnum=27R5V2&vehicleSearch=false&fromCompare1=yes&tab=Specs
The best way to improve your chances of not having a tire failure is to increase the load weight rating in pounds as shown on the sidewall .
That is measurable .
To rely on brand for improvement is similar to going to a casino .
That is not measurable . - JIMNLINExplorer IIIA 7000 lb trailer equate to 1750 lb per tire requirement.
A ST225/75-15 C = 2150 lbs capacity or 8600 lbs gross. A good match especially if the trailer sits a lot and makes short local trips but as any ST your limited to 65 mph.
A ST225/75-15 D = 2540 lbs per tire or 10160 lbs gross. Not a good match for a 7k trailer.
IMO your best upgrades will be going to a LT or a multi position tire especially if the trailer is on the road making you a living and long trips.
Depending on room in the wheel well and proper wheel pressure/wheel width requirements the Goodyear Wrangler HT in a LT235/75-15 C (50 psi) at 1980 lb capacity. Most LT tire makers carry this size.
And a Wrangler HT in a LT215/75-15 D (65 psi) at 2090 lbs capacity.
Maxxis LT U-168 are a commercial grade tire with several 15" sizes and have became popular with all types of trailer owners.
Vanco 2 from Continental another popular tire for trailer users has several 15" sizes and load capacities.
I see the Yokohama RY215 in a 700R 15 D at 2040 lbs capacity is popular on some of the other RV websites.
Do your home work on the numbers. - RVUSAExplorerHopefully you have 2 axles, thats a lot of weight for 15 inch tires.
I have used carlisles 15" radial rh tires on my 5th for 2 years now and have made several cross country trips with the 5th sitting for many months at a time in between runs. They definitely run much cooler than any other trailer tire I have used.
The big thing to remember is make sure your tire is sized correctly for the intended load. A 15% to 20% load capacity bigger than you need is a wise move. You really dont want to max out a tire. Heat is the number 1 killer. And be sure to use tire covers while you sit. the sun is the number 2 killer. - SuzzeeeQ2012ExplorerI am not sure about the details, let me ask :D
225 75 15 is the size. Trailer is 7,000 when it's loaded. We use it when we're on our trips for about 5 months, but we're sitting a fair amount.
thanks for the information so far :) - nevadanickExplorerI have 4 trailers and they all have Maxxis 8008's on them.
- RaftenExplorerI guess I will defer to The Texan as he seems to have given Carlisle tires a lot of road testing. That said I had very bad luck with them in years past on boat trailers. One summer I had three blow outs and many bucks worth of repairs. Never had a problem once I switched to LT tires.
- spike99Explorer.
If it's for a cargo trailer, do investigate LT tires as well. Especially for single axle trailers - where tire scrubbing (around tight corners) isn't a concern. - Bionic_ManExplorerJMO, but there really isn't much difference between ST tires. They all seem to be of the same quality. I have had tread separations on carlisle, Tow Master, Marathons, you name it.
I have the best luck when I keep the tires inflated to max PSI, keep speeds around 65 mph, and replace them around the 5 year old mark. I have 2 boat trailers as well as a utility trailer that all run ST tires, so I do have a little experience here. - More information on your trailer would help?
What size tires?
How much does will it weigh loaded?
How much is it used?
Looking for advice before your next adventure? Look no further.25,184 PostsLatest Activity: Sep 04, 2018
