Grit_dog
Apr 19, 2014Trailblazer
Ok if Armor all or other dressings destroy your tires then by all means do not drive on the roads with those tires. All kinds of nasty stuff out there that will disintegrate them!!! Jk
None of that stuff will hurt your tires. Period. If the tires are cracking, they are old. If you don't wear them out in a few years most will crack regardless of tire care. Just a fact of life. Not due to Armorall.
If the tire dressing buildup turns them brown, use some Bleche White for white walls. Or aluminum wheel cleaner. Strips the buildup off and makes them black again.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
