TGarrett
Aug 14, 2012Explorer
Irover wrote:
To be accurate; that tire pressure is rated at ponds per square inch. 10X100 sq. ins. = 1,000 sq. ins. x 85 pounds = 85,000 pounds pressure according to basic math. Now have you figured out why they blow all to pieces; considering also what joelc wrote. Irover
What is a Pond per square inch?
Even if your math did work, what about the surface area of the rims and sidewall, everything feels the force. What about the centripidal force due to speed applied to the gas within the tire, the wieght of the gas is increased along with the weight of the tire at rated speed. What is the 10" the width? and 100 the circumference? If 100 is the circumference that is about an 35" diameter tire, but how are we to know that since circumference isn't measured in sq in.
What about the pressure increase to to the increase in temperature?
You need to state your assumptions in order to do basic math.
As a reference a 35" tire with a 20" rim will exert approximately 87 G's of force to the outer edge of the tire at 70mph.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
