wa8yxm
Sep 21, 2012Explorer III
I made a post on another forum about tires made in china and got dinged (NOt an RV-NET forum).
Seriously the comment that gets my vote is the "You know it immed"
I will give another answer as well.. Or two
One is the weight (As expressed by the pressure) on the tire.. I mean if the tire needs 50 PSI to stay round then it's hauling a lot more weight per surface aras that a 25 PSI tire (Auto tires normally run around 27 psi).
Second is the speed it's spinning,, I blew a tire on the last trailer I owned (On the way to the dealer to trade it in on the Class A I'm in now) and I knew when it happened Same as a car tire. And hit the shoulder but that much smaller diameter tire was well and truly shredded.
It may have been running low, but I don't think so.
It was a bit over-age though.
No loss of control, trailer was light weight (Scamp) and empty (Well it had perhaps 5 pounds of "Stuff" inside, specifically a porta-potty with no water in the tank). As I said. on way to trade in).
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 01, 2026
