cummins2014 wrote:
wopachop wrote:
Dtank wrote:
*YOUR* job is to watch the guy tightening the lugs with his impact.
*ASK* the guy what his impact is set at!!..:@
I agree with what you said about auto shops over torquing. We have had horrible luck in that department.
With impact guns I would say some guys can get pretty close. My buddies all change sandcar tires with electric impacts. Dont think I've ever seen them with a torque wrench in their hands.
At home I use an air powered impact. Set it to power level 2 and let it hit 2 or 3 times is about 70ft lbs. I then torque by hand after that.
I think most shops give you lip service on the those impact guns, IMO they are set too high let it hit couple three times ,and then go thru the motions of using the torque wrench. Unless you are leaning right over the top of them , and see the nut actually move, I doubt you are getting the job done right.
I agree, and many shops will not let you in the service area to watch either. If they are working in their parking lot, you may be able to hover.
Like so many RV related, and minor tow vehicle service items, if you want the job done right, well you know... If you are not capable/knowledgeable, then a shop you trust is best option.
Oh ya, on the road, call for help??? Never have, and I have changed some flat tires under GAWD awful conditions. Being prepared is first step!!
Jerry
