_DJ_1
Aug 24, 2016Explorer II
aguablanco wrote:
Having been an expedition whitewater rafter for the last 17+ years, trips often take anywhere from 5 to 23 days with no resupply, this is one of the most debated questions we continually discuss. We actually have a rafter in Minnesota, a scientist, who built a test room with temperature controls and multiple point sensors and ran an experiment over the course of two years on whether ice lasts longer by draining or not draining the cooler. The conclusion is that ice will last nominally longer by not draining the cooler. While that may be significant to some, it is not to me. I drain to ensure that food in the cooler is not contaminated by the water sloshing around. Even though we vac bag all of our food it is important to keep in mind that vac bags lose their seal, and people with dirty hands get into the cooler to get things out, and when that happens the outside of the other bags can become contaminated and transfer that contamination to one's hands during the prep and cooking process. On a 23 day Grand Canyon rafting trip that contamination can spread a virus through a group of campers faster than anyone could imagine. If the cooler is drinks only the issue is somewhat less critical although without good personal hygiene the water can become contaminated by using dirty hands to fish out a cold beverage.
My method is to use nothing but block ice in coolers whenever possible. It cools more efficiently and lasts much longer. I also drain daily, mostly in the morning when the outside air is cooler. We have even gone so far as to put 6"-8" of water in a large cooler, 105 quarts or larger, and freeze it solid in a commercial freezer to make one large block of ice in the bottom of the cooler. One of the best things that can be done is to get a piece of the foil covered Styrofoam insulation and cut it to fit inside the cooler and let it sit on top of the food. This essentially reduces the size of the cooler as the contents are used and sit lower in the cooler. Another good practice is to keep the cooler in the shade a have a wet towel over to keep it cooler on the outside. One can also put in a quantity of dry ice on top of the food and wrapped in newspaper to keep the ice from melting on the way to the campsite. Beware of frostbite when handling dry ice. Anyway, this is my experience.
RichH
Back in our tent camping days we used gunny sacks on top of the coolers and keep them wet from the creek water. To keep things dry that I don't want wet I use small Tupperware containers. The Styrofoam idea is excellent!!
Looking for advice before your next adventure? Look no further.25,194 PostsLatest Activity: Apr 29, 2026
