univmd's avatar
univmd
Toad lost charge with charge line?
Our CRV lost charge for the first time ever even though we have a charge line from our braking system. Is this possible, what should I check, advice? With warm regards, James
  • Check and make sure you did not leave something on in the car, like the radio or blower?
    Good Luck
  • Put a diode in the line to make sure that the toad battery isn't helping to run the RV.
  • check the fuse I know youhave in the charge line! Could be blown.
  • Check the voltage at the toad both with and without the engine of the coach running. If it doesn't rise as the coaches voltage does then it isn't charging.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
