bsheet2's avatar
bsheet2
Toad on a Dolly
Hi all. 1st Class A motor home coming soon. Need to get my car set up to tow on a dolly with surge brakes. I think I would rather flat tow. But the wife is suddenly getting frugal and wants try towing with a dolly. Easy for her to say!
RV >> Thor Challenger 37YT
Car >> 2014 Honda CRV
Tow dolly has surge brakes.
So, I want to pre-wire the CRV to use brake lights, turn signals, etc and not use the lights on the dolly when towing.
Also I want to charge the CRV battery from the RV power when towing.
Would like to use the RV 7 pin connector with a cable that plugs in to a socket on the front of the CRV. Only 1 cable if possible. I was told that the RV 7 pin connector is prewired with a 12 volt hot wire that could be used to charge the car battery.
So, what parts do I need?
Can this be done?
Is this posted in the right place???
Thanks!
  • Oh, the CRV is front wheel drive.
    Regarding cost. I got a quote of $3400 to install the base plate, all wiring and provide the tow bar for flat towing. Then would have to purchase the braking system. So I figure at least $4000 for flat towing.
    I just ordered a dolly with surge brakes for $1900 (delivered). So now all I need is wiring for the CRV.
    Did I miss something??
    Thanks!
  • I think you are going to spend about the same amount of dollars using a tow dolly as setting up for flat towing. You did not say which drive your CRV has. Look at this website to verify towing. Remco
Looking for advice before your next adventure? Look no further.25,115 PostsLatest Activity: Mar 04, 2025
