monkey44's avatar
monkey44
Nomad II
Nov 30, 2020
Toad Service ??
Just called about an oil change and battery for the BMW ...
Service folks said: A hundred-fifty bucks for an oil change. AND, then three-hundred for a battery, PLUS one-hundred eighty for a battery reset.
That's six hundred thirty bucks for oil change and new battery. :( :(
When I do these on my Chevy PU, I can reset it sitting right in the cab.
Anyone explain those costs?? I know, BMW expensive, but oil is oil and a battery is a battery. Maybe someone can explain this for me.
After we moved, no BMW near us, so a couple hours drive. Would rather do this local if possible, even if higher than a 'regular' auto service, but BMW says ONLY BMW can do this. Year is 2014 X3 ... 30K miles.
  • Have you checked a local mechanic? I'm only a bit farther from Cape Cod :W and when I had an issue with my MB Sprinter I asked my local guy if he could deal with it. Absolutely no problem. Maybe BMW is the same but they don't want you knowing that.
    Dave
  • Break out the owners manual.
    Learn how to reset the internal computer, it likely will tell you. and then any auto parts store will replace the battery, you just have to reset the computer, and save about $200.
    If all else fails,,,,, check out youtube.
    Also, get yourself an OBD-II code reader, many small problems can be identified saving you thousands vs a STEALERSHIP visit.
Looking for advice before your next adventure? Look no further.25,191 PostsLatest Activity: Apr 04, 2026
