Dutch_12078
Apr 01, 2014Explorer III
There's an easy test to see if the NSA vacuum boost pump is worth installing on your toad. Run a predetermined route where various braking situations will be needed with the normal ReadyBrake hookup. Then run the same course with same setup, EXCEPT, this time start the toad's engine and leave it idling while you run the course. If you notice a significant improvement in the braking action, then the add-on pump will be a useful addition. No significant change? Then it's not needed.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
