UsualSuspect
Apr 01, 2014Explorer
ezgoin wrote:
Since my Fiesta requires the negative battery cable must be disconnected for towing does that mean my only option for a brake system is mechanical, like ReadyBrake? There will be no power to the 12 volt accessory plug.
You can hook up a line directly to the battery and run it inside the vehicle. Make sure you put a fuse or circuit breaker on it near the battery in case there is a short.
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
