- Horizon170ExplorerWe use whatever we have at home. Right now it is Scott 1000.
No reason to buy the expensive RV TP Unless you are just trying to get rid of your money faster. :) - B_O__PlentyExplorer III don't put mine in the toilet..I save it in a paper bag then use it for starting fires. It gives them a nice aroma..
B.O. - down_homeExplorer IISome of the reasoning for using easier dissolved paper is traceable to the forced indtorcution of low waater use toilets. They clog up with just hint of using more than one square of paper. Back when they started it one of the guys, in the officce put a sticier on the stalls "be paper conscious use both sides."
- coolmom42Explorer IIWe do not put paper in the black tank, partly because the trailer is used but not moved and had a couple of issues with clogs in the dump line, from someone (not me) putting big wads of TP down with not much water.
We use normal to generous amounts, fold it over neatly & wrap if necessary. Put it in the small bathroom trash can lined with a Walmart bag, which is emptied daily. - B_O__PlentyExplorer II
coolmom42 wrote:
All I can say to that is EEEeeeyuck!
B.O. - TyroneandGladysExplorerLOL it don't matter if you would believe my stepfather would believed you only needed 2 squares of TP for any job. YES HE DID TAKE IT OUT OF THE BATHROOM AND WOULD HAND OUT THE 2 SQUARES AS NEEDED..
- Sillybugs2ExplorerWe use whatever I bought the last time on sale. Never had an issue. Last time was Angel Soft, before that Cottonelle and before that Kirkland from Costco. We use plenty of water and don't sweat it.
PP I knew a family growing up who put all paper in wastebasket. Ewww! - noe-placeExplorerWhat's toilet paper? (Figured the question was as germane as the current answers).
- portscannerExplorerWe use John Wayne toilet paper
- FunnyCamperExplorer IIcheapest 1 ply I can buy for the rv.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
