Lynnmor wrote:
NanciL wrote:
After you drain and flush, put a gallon of water with the proper amount of chemicals in - Problem solved
Jack L
That gallon of water may not be enough. Systems that have the drain valve some distance from the tank need to have water added sufficient to fill the pipe and then another gallon or more of water with the chemicals. Don't add the chemicals first because they will just stay next to the drain valve.
Making sure there is sufficiant water in the tank after the flush is what I belive I need to start doing. Case and point, once we are at a campground and I add water to the tank smell is gone.
Thanks to everyone for your thoughts on this, I appreciate it.
Oldcow
