JRscooby
Oct 27, 2020Explorer II
If I was going to be torqueing the bolts, I would put a jack under to support. Will that change the final reading/actual torque on the bolt? No. But I'm lazy, don't like to do extra work. Likely the person turning the wrench will not see it, but as he bears down on the wrench the vehicle goes down. Then when release pressure to get another flat, vehicle comes back up.(More likely to see that.) Every stroke, as the bolt gets tighter, more of the force is used to compress springs before the nut starts to turn. That is wasted work.
Something else to think about; I don't know how many times I have had a helper, (confess, once I was the helper) when I have pulled a bolt to get it torqued, then hear "Need to back it off, wrench is locked" Yes, arm wrestling when the other guys wrench is 4 times as long as yours it is easy to wedge your wrench against something solid. By yourself even easier. Hold a bar or board between wrench and solid so you can have leverage to pull it out, get play, and your wrench back.
BTW, most of my life I would of turned things so I was lifting instead pushing down. I could lift more than I weighed, let alone what weight I could get on the wrench. But I have gained over 100 lbs, and lost muscle
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
