camp-n-family
Apr 09, 2015Explorer
I towed a hybrid of similar size and weight with a V6 4Runner for a couple of years. I think you will be fine with that set up as you're well within the TV limits and capabilities but then everyone has a different idea of what they are comfortable with. It worked fine for us but might get tiring for 2k trips. Try it with what you have, then decide.
The V6 engine is strong and has plenty of power. Our old '03 only had the 4sp trans and gearing that wasn't ideal for towing. Toyota recommends locking out overdrive when towing which meant towing in 3rd. It handled the weight but struggled with wind resistance and would get bogged down in the wrong gear. The '07 should have the 5sp which is much better suited. Slightly higher RPMs but better power and MPG. Don't be afraid to let it rev. We eventually traded up to a V8 model which towed with ease.
You will want to use a WD hitch with sway control. The short wheelbase isn't ideal and will benefit from this. The only downside is you'll have to replace the stock factory mounted hitch. The stock V6 hitch is only bolted to the cross member and is not designed for use with a WD hitch. Get the frame mounted one that came on the V8 model and Lexus SUV or Curt makes a nice aftermarket one (13445?). You can install it yourself with basic tools. Hardest part is getting the stock one off.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 27, 2026
