way2roll
Oct 20, 2021Trailblazer
Normally I would recommend the ready brute elite tow bars as they have an integrated mechanical brake so there is no separate braking system and nothing to fail. Once it's set up there is no installing/uninstalling the supplemental braking system. But since you already bought a supplemental brake before buying bars or base plates, I can't be of much help in that category.
We used Blue ox base plates on our CRV when we towed it and they were easy to install and will work fine with a variety of bars. If you aren't fairly adept at DYI and have the proper tools you may want to take this to a shop. It was about 4 hours labor so expect estimates accordingly.
There is no set up for the bars per se. They simply go into your MH receiver and hook to the clevis' on the baseplates on your vehicle.
Looking for advice before your next adventure? Look no further.25,203 PostsLatest Activity: Aug 08, 2026
