BrianinMichigan's avatar
May 25, 2016
Tow bar
I'm getting ready to start towing a jeep. Can the tow bar be left pointing up when driving around? It would be a lot easier to do it that way instead of having to unclip everything and stow it away. It would be securely fastened in the up position.
  • Lucky alot of us dont care what other people think. There has been tow bars on Jeeps since the first one got towed. Go for it.
  • RJsfishin wrote:
    I see it done all the time. So if you don't care how tacky it looks, go for it.
    Mine stays on the MH in a horizontal position.
    x2 on the tacky factor
  • I towed several different Jeeps with a similar towbar, bolted to the front bumper.
    It worked. And, it worked well! The really important part, it only cost $145!
    When not towing, I used the safety chains to tie the towbar up. That worked just fine, as well.
    Yes, it is my understanding that one can not do that in California. But then, We have never taken the motorhome to CA, and it is doubtful we ever will.
    Here in Montana, though, I used to run around with the towbar sticking up on the front of the Jeep all summer long, no problem.
  • I see it done all the time. So if you don't care how tacky it looks, go for it.
  • You may run into issues in some states with obstructed windshield view laws. I've heard California enforces theirs, but have never run into anyone that was ticketed.
  • If that is the tow bar you want you can certainly leave it on the jeep. One that stays on the motor home, while considerably more expensive, is much easier to hook up.
  • Depending on the tow bar, it should stay attached to the back of the MH in the receiver, in a vertical position. You're just pulling two pins to unhook it from the Jeep. Otherwise you have to unhook the hitch from the receiver which would take longer. And then it's going to rub against the hood of the Jeep.
    Tow bar set up on front of our 2002 Jeep Wrangler
    Pull the pin on each side
    The tow bar fold together and folds up staying locked upright at the rear of the MH
    Bill
Looking for advice before your next adventure? Look no further.25,185 PostsLatest Activity: Mar 05, 2026
