JayBuchanan's avatar
JayBuchanan
Tow Dolly Recomendations
I would like to see if there are tow dolly that are recommended by the groups. I will be using my 2011 Class C (F450 chassis) to tow either my 2014 Ford Explorer or 2009 VW Jetta.
In your opinion, is electric brakes needed? I will be towing mainly in NM, TX, and surronding areas. I am also looking for a tow dolly that will accept the 17" rims on the VW and the 20" rims on the Explorer.
Thank you in advance!
  • The Demco kar kaddy is the Cadillac of car dollies for sure. Find a used one and the price will be good too. I sold mine about a month ago.
  • Bought a Master Tow with surge brakes about a month and a half ago for my RAV4 fwd with 17" wheels and have put about 1000 miles on it. So far, no problems and works great. Would recommend.
  • I can't speak to what toads can or cannot be towed on a dolly but I've been very happy with my Demco Karkaddy SS dolly for the past 11 years. It's fully galvanized so you never have to worry about rust, has surge brakes so any vehicle can pull it safely without having to install a brake controller, its ramps fold up and the tongue folds back to reduce home storage by almost 50%, it has rack & pinion swivel system rather than swiveling wheel plate and Demco is very receptive to answering questions if needed. It may cost a little more but I've felt it was worth it.
    Dave
  • Can't the 2014 Explorer be dolly towed if it's front wheel drive?
    The OP didn't specify if his is front or all wheel drive.
  • First off the explorer cannot be towed on a tow dolly. You need to install a transmission pump and tow it 4 down or put it on a trailer (which is more weight than your F450 chassis can handle). The Jetta will be fine on a tow dolly, and yes the dolly must have either electric or surge brakes, it is the law.
    Ours is a Master tow dolly, we are the 3rd owners of it, and it is still in great working order. I just put new tires on it. We use it to tow our 2003 Kia Sedona.
    Wheel size will determine what straps you will use, the dolly itself does not care what size the wheels are. The dealer where you purchase the dolly from will have the correct size straps for your need.
Looking for advice before your next adventure? Look no further.25,200 PostsLatest Activity: Jun 29, 2026
