BrianinMichigan's avatar
Aug 06, 2019
Tow Dolly resurrection
I have an old tow dolly that I want to put back into service. It does not have brakes on it. I am wondering what is a better braking setup, drum brakes or disc brakes using the surge controller. I am more concerned with towing in the mountains than on flat land.
  • I have disc surge brakes on my boat trailer. They work great!
  • Do you want the brakes to work, or just to be there for an emergency break-away situation?
    We have drums with the surge actuator on our dolly for a break-away only, and having pulled thru the mountains multiple times never really felt that we needed added braking from the dolly.
  • I was going to put brakes on an old Demco Kar Kaddy a few years ago, then I found out that the spindles had no flange to mount the backing plate on. I gave up on that idea. I quit towing the PT Cruiser instead.
    You might want to check to see what is required for your dolly to install brakes. It quite possibly might be easier to find a dolly with brakes instead of trying to install them on your old dolly.
    As for drums or discs, I don't know which would be "best" in the mountains. Same goes for electric or surge. I have used both on various trailers in the past. They both worked just fine for me.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
