Cfgrove99's avatar
Cfgrove99
Towing 2005 Jeep Wrangler
I have a 2005 Jeep Wrangler and I'm looking to tow it four wheels down what all do I need and what is the best equipment?
  • "if you DONT disable the ignition you'll run the battery down (while towing)."
    Not true on a 2005! 2006 and prior Jeeps had an "OFF, not locked" position in the ignition switch. THAT is the position the switch has to be in while towing (as noted in the Owners Manual).
    I towed a 2006 Wrangler Rubicon Unlimited many miles with the switch in the "OFF, not locked" position.
    Since my son's 2003 Rubicon has that type switch, I'm fairly sure the 2005 does as well.
  • I towed a 2005 Wrangler many miles. I used a Demco base plate; very easy and quick to install. I used the Ready Brute tow bar with the Ready Brake system; worked flawlessly over thousands of miles towing. I installed a second set of bulbs in the upper portion of each tail light. I used a commercially available trailer wiring harness to connect the lights to the wiring harness on the motor home.
    Ray
    Well Sir,
    There's a dozen different styles/types of tow bars that would work. Part of your choice of which one to pick would be if you're the type that would like the tow bar to remain on the coach, when disconnecting from the Jeep. If not, there's the ones that remain on the toad and, they're removed with ease too. Stowmaster is one that comes to mind.
    You can find great deals on Tow bars, both kinds, on ebay and, in pretty darn good shape for a lot less than new ones.
    As for "base plates", well, lots depends on what kind of bumper you already have. If it's an Off road style, you can adapt tow bar brackets to that bumper and you're done. If it's a stock tin bumper, then you've got to go with that gaudy base plates that many companies offer.
    As for wiring, talk about easy. I've wired seven different Jeeps including one just like yours. All the tail light wiring runs right along side the drivers left calf. It's tucked under that door sill.
    All that's needed to be done is, expose that section of wiring, determine which wire is the left turn/brake, right turn/brake and, marker/running lights. You can "T" right into those at that area and, you don't need to get those fancy high priced "Diode kits" from RV supply houses. All you need is some Radio Shack heavy duty diodes. They run a whopping $4.00 for about 3 or 4. All that's needed is two. One for the left turn/brake and one for the right turn/brake.
    Then, "T" into the tail/marker lights and, you're done. It works absolutely flawless. As far as safety chains or cables, those too can be built into the brackets that are attached to the bumper. It's all pretty easy with that era Jeep. Questions? PM me and I'd be glad to assist. Good luck.
    Scott
    slightly too old to use the factory/Mopar towed vehicle wiring harness (82211156AB).
    you'll need something to enable the tail/stop/turn lights while towing....
    you can use magnetic lights (but theyre a pain the butt).
    there are a few alternative (including the installation of extra bulbs in the factory taillights)
    check out these tow-bar wiring options -HERE
    you'll need some base-plates mounted to the Jeep (front) so you can connect a tow bar too....and don't forget the safety chains between the jeep & the coach.
    on Jeep PRIOR to 2009 (iirc) that have a steering wheel lock - you'll need to pull a fuse (under the hood) to disable the ignition & then you'll need to insert a key in the ignition & turn the key to the ON (aka unlocked steering wheel) position - while TOWING (to prevent the steering wheel & steer tires from locking / dragging thru turns).
  • Tow Bar, Base Plates, Braking System, Wiring, Isolation Diodes. As far as what is "best" everyone has a different preference.
Looking for advice before your next adventure? Look no further.25,116 PostsLatest Activity: Mar 11, 2025
