footslogger's avatar
footslogger
Towing 2006+ Honda Element 4-down: Real life experiences?
We have been towing a 2003 Honda Element AWD automatic for about 9 years and over 80K miles without any problems. We LOVE our Element. But alas, the end is near for the old girl, and it's about time to put her down and be looking for a replacement.
I know Honda endorsed the Elements for flat towing during model years 2003-2005 (with specific procedure involving the shifter, etc.), and removed the endorsement for subsequent years. I recall reading on this forum that some folks have been flat towing 2006 and later models, but can find only one testimonial for a 2011 on this forum, and it's for a 2WD. We have found a 2011 Element AWD automatic that we really like and would buy it tomorrow if we were comfortable we could tow it 4-down without causing damage.
So, please let me hear from those with real experience towing 2006+ model years. Let me know if you had any problems or if everything went well, particularly with the drive train. Please also state whether yours is a straight drive, a 2WD vs AWD and 4-speed vs 5-speed transmission. Please do not waste your time telling me what Honda says about towing later model Elements. I know what the company line is.
Thanks for any help you can provide on this topic.
  • I work P/T for a couple of dealers around town and one of them is a Honda. Not sure exactly what year the company changed (I know that is not a lot of help for you!) but even after Honda withdrew their towing endorsement of the Element it was still on the same 'platform' as the CGV which they did endorse. I believe that has again in the last few years ('11 or '12) The service department will tell you that you should not do it, but they have been instructed that in telling you they are the same might result in a law suit if an owner screws up and burns out a tranny.
    I don't have info on the AWD. We towed our 03 thousands of miles with no trouble and still keep it around even after we put the Wrangler into service as a towed
  • OP here. Anyone else have any experience flat towing a late model Honda Element?
    Let's hear from you!
    footslogger
  • I tow a 2WD 2011 Element. It's the same drive train as the CRV.
    Go for it.
  • Here is what Remco Towing Products says about towing a 2011 model:
    "2011 Honda Element LX 4WD I-4 2.4L cyl 5 Speed Automatic MNZA/BZKA
    Notes
    •Towable as is with speed and/or distance restrictions. Please see Owner's Manual for confirmation and procedures.
    •It is not recommended to tow this vehicle over 65MPH
    •When towing for an extended period of time, start the vehicle as often as possible and allow it to run for five minutes to prevent battery drain.
    •Officially from both Honda and REMCO the vehicle is not towable. However, we at Remco have a large number of customers who are flat-towing that vehicle behind their Motor Home and they are not having any issues. Follow the "Emergency Towing" procedures in the owner's manual to a "T" except ignore the restrictions and follow those procedures each and every time you tow. NOTE: If you choose tow your Honda, and have any damage to the Transmission as a result, you will have to pay for that expense out of pocket. It is nothing that Honda or Remco will warranty. Also, it should be noted that Remco sells no aftermarket product (Lube Pump or otherwise) to make this car towable."
    This is the same statement they say about nearly every Honda that is towed.
    So based on this non-approved approval, I would say the Element is towable. Also from a mechanical standpoint the Element and the CRV have the same driveline components and all CRV's are towable up to 2014, but not the 2015.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
