klewis98
Jun 20, 2014Explorer
Depower the vehicle by removing the negative
cable at the battery. This procedure must be
followed or the steering column could be damaged.
Cover the negative battery post with a
nonconducting material and prevent any
contact between the negative battery terminal
and the negative battery cable.
Notice:
If power is provided by accidental contact of
the cable and terminals, damage to the towed vehicle
may result, which would not be covered under the New
Vehicle Limited Warranty.
9. Verify the steering column is unlocked.
10. Release the park brake only after verifying the
towed vehicle is attached to the towing vehicle.
11. The ignition key must remain in the towed vehicle.
Manually lock the doors and use 2nd key for
access
Notice:
access
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 12, 2026
