Thunder_Mountai's avatar
Thunder_Mountai
Explorer II
Jul 11, 2021
Towing 2018 Jeep JL Unlimited with dolly?
We're not new to the dinghy world having towed several JK Jeeps four down. Have 2018 Rubicon that I would like to tow two down because I found a really good deal on a dolly with brakes, lights and correct capacity. Would cost much less that base plate, tow bar, lights and brake for four down. Book says not to tow four down. Debate on the Internet over this question has inconclusive answers. Anybody here towing a Jeep JL Unlimited with automatic using a dolly?
  • Can’t be done unless you remove the rear driveshaft! If you tow it in a dolly and leave the driveshaft connected you will burn up the T-cas. Both output’ (front and rear) need to be the same speed!
  • Compare the price of the dolly et al to the price of the NSA Ready Brute Elite package plus baseplate. Not sure why anyone would want to hassle with a tow dolly over 4-down unless of course you gave another car you want to take with you.
    Does the debate you're seeing involve disconnecting the driveshaft?
    I think the owners manual eliminates any doubt about dolly towing.
  • There really is no debate, owners manual will show you the way.
  • No debate here. Follow the manufacturer’s recommendation. Jeep has your best outcome in mind.
  • not doable, 4 on the ground or 4 off the ground, only
Looking for advice before your next adventure? Look no further.25,206 PostsLatest Activity: Aug 22, 2026
