Ivylog
Dec 28, 2015Explorer III
The good news is the hitch is rated high enough but if you use all of the rigs weight carrying capacity of 22,000 lbs that only leaves 4,000 for the boat. You need to know what the empty weight of the rig is as suggested above. Since you are buying this rig (wife is adamant she wants this RV) and the boat trailer has at least one axle with brakes I would haul it without any fresh water and half a tank of fuel to reduce your GVW. You can actually us this to your advantage in that she cannot bring stuff because it will make the rig too heavy... do not let her see your tool box.:W
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: May 29, 2026
