Artum_Snowbird
Apr 26, 2016Explorer
Certainly straining the engine is a small part, and easily controlled by not going with the gas pedal all the way down. What I found most disconcerting as I neared my load limit was the feeling of being pushed while on long downhill sections. The only way to control descent is by putting the truck into a lower gear, and letting the engine spin. With a small engine, there isn't as much resistance against over-speeding compared to a bigger block engine.
There really isn't any way that will last for a long down hill other than engine back pressure, you will want to brake so much, and you just can't use your brakes like that.
Looking for advice before your next adventure? Look no further.25,186 PostsLatest Activity: Mar 13, 2026
