altenbu's avatar
altenbu
Towing a 1500 2014 silerado
I'm towing a 1500, 2014 Silverado, and service bulletin 13-00-89-007 says to disconnect the negative side of the battery. My mechanic called GM and they told him to disconnect the positive side. A disconnect is necessary due to electric steering system, is my understanding. Anyone with same experience or knowledge please respond.
  • Disconnect either positive or negative with the same effect.
    However, disconnecting the negative connection presents less risk for shorts, if you understand negative vs positive ground systems.
Looking for advice before your next adventure? Look no further.25,187 PostsLatest Activity: Mar 17, 2026
