Beverley_Ken
May 07, 2021Explorer
Check with your car owners manual, under towing behind a vehicle or recreational towing. Each manufacturer and model, transmission model could all be different. Transmission pump fluid connection etc., even idling the engine may not operate the transmission pump, if the transmission is in neutral.
2nd part of your inquiry, towed vehicle braking systems are generally designed to work with the car NOT running and any power assist bled off. On our Brake Buddy system, after installing, final step is to press a button to cycle the Brake Buddy five times to bleed off any power assistance. If you were to leave the towed engine running, any time the brakes were applied, it would probably lock up the towed vehicle brakes.
Ken
Ken
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 27, 2026
