theoldwizard1
May 07, 2021Explorer II
The problem with towing "4 down" is somethings inside the transmission will spin. The spinning cause heat. The pump is not pumping so the fluid does not go through the cooler.
Some transmissions can handle the heat,some can not.
Looking for advice before your next adventure? Look no further.25,207 PostsLatest Activity: Aug 27, 2026
