whemme's avatar
whemme
Explorer II
Jul 15, 2016
Towing a 2016 VW GTI
For those interested it is now possible to setup a 2016 VW GTI with manual transmission for 4 wheels down towing. Blue OX now has a base plate for this car - mine was the 1st to be equipped with it. See attached photo below.
To eliminate the need to have the ignition switch in the ON position so that the steering would be unlocked, I had a mechanic disassemble the steering stack and use a carbide cutting tool to cut off the pin that locks the steering. Also, this VW's 12 VDC power receptacles are not powered when the ignition switch is OFF and key removed. However, the yellow 20 amp plug in fuse in the fuse holder under the driver's side dash can be unplugged and moved to a 2nd plug in location that changes these receptacles so they stay hot with the key removed so that you can power a braking systems such as the Brake Buddy or the Blue Ox Patriot.
  • Yes, various VW models with manual transmissions can be towed 4-wheels down even though the owners manual does not have a RV Towing section in it addressing the issue. The Golf and Beetle models seems to be the most popular versions towed.
  • I'm confused, so some vehicles can be towed even though they aren't listed on remco's site?
Looking for advice before your next adventure? Look no further.25,163 PostsLatest Activity: Sep 05, 2025
