Ole_B
Dec 14, 2017Explorer
Keep in mind this procedure is only for 2017 and older Equonix. The new 2018,which I now have has a new procedure.
1. Push the start button, with key in possession.
2. Shift to park.
3. push start button to turn car off and into acc mode.
4. Make sure you are in acc. ,may have to push button twice.
5. Turn all Accessories off you can see. (I include the lights)
6. NOTE: The center display screen you will NOT be able to turn off. This screen will turn off after about 30 min. GM is revising the manual to also state you need to install a power line from the coach to charge the car battery.
No fuses are pulled, Gm says power is needed for the electric steering.
2. Shift to park.
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
