Executive45
Dec 15, 2017Explorer III
Several have asked about the battery charger install. At first I thought it'd be very simple, and it was. But, finding the correct parts turned out to be a task. Here are pictures of the install along with where to get the correct parts and cost of same. Keep in mind, my car is a 2014...Dennis
The fuse box is located in the engine compartment.
Squeeze the two connections and pull up to remove the cover.
Fuse #16 is this one.
20amp JCase fuse. PITA to remove so I'm putting in a switch.
I mounted the Battery Charger here for convenience.
The charger is fused, so I zip tied it here for access.
Run the wire from the fuse to the appropriate connector on your car.
Hooking up the charger. The post (blue arrow) unscrews using 10mm wrench. Hook up positive (red arrow) under this post and reinstall. Finally, hook up the negative (black arrow) on this post and reinstall the nut.
If you're going to add a switch, you'll need one of these.
I added my switch here so it'd be out of the way of wayward feet.
That's it. Took me about an hour for the install. I purchased the Charger HERE. The JCase fuse holder was a PITA to find. Waytek carries them for $5.81 but charges $15 S/H. I purchased mine HERE for $9.17 but only $3 S/H. Any questions, feel free to ask.....Dennis
Looking for advice before your next adventure? Look no further.25,211 PostsLatest Activity: Sep 01, 2026
