dahkota wrote:
Your fifth wheel GVWR has no relation to your truck GVWR. Your 12K 5er weight does not leave you 3K lbs. for passengers and pin and whatever else you put in the truck.
For the F250, the GVWR is either 9800 lbs or 10K lbs. Assume you are looking at the 10K lbs. version. With a diesel engine, and the FX4 4X4 you mentioned in another thread, and the supercab or crew cab (you mentioned carrying more passengers) your truck will weigh at least 7400 lbs. Probably closer to 7600 lbs. I have a similarly equipped truck and mine weighs over 8K lbs.
This leaves you with a MAX of 2600 lbs for payload (10,000 - 7400 = 2600: GVWR - actual weight = payload).
Your 5er will have a pin weight of between 2K and 2400 lbs given the specs above. That leaves you with between 600 and 200 lbs. for passengers and other stuff in the truck, including the hitch.
X2
Similar to what I previously posted, Diesel + 4x4 = F350 if you NEED the PAYLOAD to be higher than 2K or so.
My F250 Supercab 2wd with 6.2 unladen weight is 6011 lbs, a 2013 F250 with diesel and 4x4 WILL have an unladen weight around 7.4K or nearly 1400 lbs HEAVIER than my 6.2.
The payload is determined by the Gross Vehicle Weight Rating - the unladen weight. In most cases the truck owner "may" have the "option" to license the F250 at 9K or at 10K (this is the way PA is for registration). In my state registering a diesel 4x4 F250 at 9K weight makes for almost no payload (registration goes through the roof for the higher the weight classes).
With the 2011 and up 6.2s you really don't "need" the diesel engine, the 6.2 is a towing monster and in my case saves a ton of money in registration fees, diesel fuel costs and the higher upkeep costs..
