j-d wrote:
Not all dollies have brakes. There may be a recent legal requirement for manufacturers to install them on new dollies, but I can assure you there are used dollies both with and without brakes. I looked at Acme's site and they had "idler dollies, no brakes" for sale new.
Most dolly brakes are "hydraulic surge" meaning the RV's stopping will cause the dolly to try to push the RV and that force applies its brakes. You can probably find (and certainly add) brakes as a kit, and if you want, you could install electric brakes with a controller in your RV. This limits you to using only tow vehicles with controllers, but electric brakes are more flexible in use.
I want to mention that this question is a little like "which motorhome to buy?" questions. The best chassis, best roof, best warranty... don't mean much if the family can't stand the floor plan.
So in that vein... What do you need your Toad to do for you at your Destination?
If I didn't need the heavy 4*4 as my at-destination driver, I'd look for a used dolly with brakes and tow the Prius. A used dolly with brakes will cost you less than a new tow bar, baseplate, and braking system.
But get the two vehicles to a truck scale and confirm what they actually weigh.
You live in hilly country. I really think the Trailblazer is going to make you disappointed in the RV's hill climbing performance. The hack for mountain driving, of course, is to disconnect the toad and have somebody drive it separately from the RV.
Ditto on the dolly set up being less expensive.
And as I mention before you will be unhappy yanking a 5,000lb car around. Making your RV'ing experience not so much fun. I most certainly would not tow a car that heavy in the mountains with my V10.
My toad weighs 2,800lbs. On the flat no problem but I KNOW it's back there when even going up slight hills on the interstate.
