wcripley
Jun 09, 2013Explorer
I have a 2006 Ford Escape Hybrid AWD. I tow it with 4-wheels down, and was told by Ford engineers that they don't recommend towing with a dolly at all. I have not had a problem towing it all over the USA, sometimes 400 to 500 miles a day. I learned the hard way to double check and make sure it is not in gear when you tow it. Both times that I did, even though it was very brief and not more than 100 yards, I ended up with a problem where the car would die after a few hours of driving. It turned out to be a pump in the transmission. This has happened twice, and those were within a day or two of starting off towing the car with it in gear. Towed properly, 4-wheels down, ignition key in the accessory position with all electronics inside turned off, in Neutral, I have never had a problem.
I am fixing to buy a towed vehicle braking system for my Fleetwood Southwind and Ford Escape Hybrid. I have been looking at the US Gear Unified Tow Brake. Does anyone have any opinions or suggestions, particularly with the same rig?
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 09, 2026
