Richard_999 wrote:
I read the owners manual in the car. It had absolutely NOTHING to say about it .
I have tried calling dealers. I got one YES .. one NO .. and 2 said they would call me back .. and did not !
By the way .. I am interested in an AUTOMATIC transmission version.
Richard
From the Ford Focus manual.
Vehicles with an Automatic Transmission but No Push Button Start
System
Note: There must be battery power to properly move the transmission’s
internal components to position N in Step 3. In addition, moving the
gearshift to position N without first turning the ignition to the on (II)
position limits the towing capability to 35 mph (56 km/h) and 50 miles
(80 kilometers).
1. Release the parking brake.
2. Turn the ignition to the on (II) position.
3. Press the brake pedal, then move the gearshift to position N.
4. Wait for TRANSMISSION READY to appear in the multi-function
display, then turn the ignition to the off (0) position and release
the brake pedal.
5. Disconnect the negative (black) cable from the battery.
(The anti-theft system does not function until the battery cable is
reconnected.) See Changing the vehicle battery in the
Maintenance chapter when disconnecting and reconnecting the
battery cable.
• The maximum towing speed is 70 mph (113 km/h).
• There is no limitation on towing distance.
When done towing, start the engine within 15 minutes of reconnecting
the battery cable. When reconnecting that cable, tighten it until it is
snug against the terminal. Be careful not to over-tighten.
202 Towing
2014 Focus
