Not_a_Clue
Jun 04, 2015Explorer
btcruzer wrote:
Just bought a Tracker automatic 4WD ... assuming that is good for towing 4 down ? just kick the transfer case into neutral? What to do about the steering ? I assume the steering wheel should be unlocked while towing. It looks like some mechanical connection between the ign. key and steering wheel. Just leave the key on?
The best way to get the details is the owners manual...if you have it. It has a transfer to put it into neutral so odds are it is okay, but need to know if you have to pull a fuse or anything else.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
