rockhillmanor
Jun 04, 2015Explorer III
Better check to see if you have automatic lock out hubs or not.
If you do you HAVE to change them out to manual hubs BEFORE towing it.
Tracker went thru a ton of production changes over the years. Each one is different info.
You really NEED to do a search on the year and model of your Tracker to get the right towing information. Some of them you have to start every 250 miles to circulate the trans oil, AND you might have to put it back in gear to do so.
Also buying the correct base plate to fit which production model Tracker you have can sometimes be a problem. I know it was for my Tracker.
What year and make do you have? If it matches mine I can give you the links for the towing info.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
