rockhillmanor
Jun 05, 2015Explorer III
I would be willing to bet the auto trans eliminates towing 4 down, unless you are willing to disconnect the drive shaft.
If the Tracker is an automatic trans AND also a 4x4, you then have the 4x4 shift to move into neutral which disengages it allowing towing 4 down. We don't know what the OP has.
OP needs to post year, make and model of his Tracker.
OP also needs to check the owners manual to see if the vehicle is towable 4 down. Look under recreational towing in the owners manual.
I hope you bought one that is.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
