mowermech
Jun 05, 2015Explorer II
The ignition switch in a 1997 vehicle should have the "OFF, NOT LOCKED" position, usually one click from "OFF, REMOVE KEY" position. If it does, THAT is the switch position to use when towing. Yes, you will have to leave the key in the switch. Yes, that position does unlock the steering.
I simply do not understand why the design engineers decided to eliminate that position from the switch!
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 19, 2026
