rockhillmanor
Jun 06, 2015Explorer II
mowermech wrote:
The ignition switch in a 1997 vehicle should have the "OFF, NOT LOCKED" position, usually one click from "OFF, REMOVE KEY" position. If it does, THAT is the switch position to use when towing. Yes, you will have to leave the key in the switch. Yes, that position does unlock the steering.
I simply do not understand why the design engineers decided to eliminate that position from the switch!
X2
it is very easy to have it in the wrong position on these Trackers. Mine had 2 positions for acc. One locked the steering wheel one did not.
When I picked mine up from an RV shop after having all the towing equip installed THEY had it in the wrong position and when I pulled away the steering wheel was locked tires skidding.:R
I always gave the steering wheel a turn each and every time I hooked it up to make sure it was not locked.
Looking for advice before your next adventure? Look no further.25,204 PostsLatest Activity: Aug 13, 2026
