j-d
Apr 07, 2016Explorer II
The issue leading to transmission failure, manual or automatic, is the lubrication provided when the Engine is running that isn't there when towed. Some early automatics had a "rear pump" which was why we could push an automatic to start the car back in "the day" and no longer can. No rear pump. Similar idea in manual transmissions. If they don't kick lubricant around while towed, manufacturer isn't going to call it "recreational towable."
But some hedge their bets by saying it's OK to tow, but stop every few hours and idle the engine, in Neutral, Clutch engaged. They're figuring enough lube will stay in play at least that long.
So I'd suggest: If you don't disconnect the toad and drive it during an overnight stop, idle it in neutral in the morning before you roll. You're gonna stop for one reason or another every few hours. Idle it again then.
Please understand, I'm saying this about Manual Transmission/Transaxle, not Automatic. If manufacturer says don't tow an automatic, Don't.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
