Bobbo
Nov 03, 2013Explorer III
pa traveler wrote:
Thinking about towing behind a truck camper,never towed any vehicle before. Can you tow 4 wheels down? Someone mentioned you turn key to on position so steering will work,is this correct? If you cant tow a Toyota outback this way,will consider a different small vehicle. Any info for first time towing appreciated,thanks.
I don't know if a Toyota Outback can be towed, your owner's manual is the answer there. Look under "Recreational Towing" or something similar.
DO NOT TURN KEY TO ON POSITION! Some keys can be left removed. Some can be turned 1 click to unlock steering. Some can be turned to ACC and a fuse removed. But, NONE are towed with the key ON. Again, your owner's manual will specify the proper procedure.
I have a Subaru Forester, which is similar to the Subaru Outback. It is towable 4 down as long as you get a standard transmission. The Subaru automatic transmission is not towable. For what it is worth, I will always have a Subaru as my tow vehicle. I like its ease of towing setup and symmetrical 4 wheel drive.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jun 10, 2026
