blt2ski
May 20, 2018Moderator
I do not have moderating ability in this area. I also do not have issues with opposing views, and do not personally delete posts accordingly in the area I do moderate.
after rereading my initial sentence, I was trying to point out, that the tow specs the automotive engineers have speced out, the minimum speeds on freeway grades are 5-10 mph LOWER than typical state minimum speeds. State of washington is 40, so the 35mph minimum for rigs over 15-20K lbs total is too low. Under the minimum is 40. Michigan per another poster, the minimum speed on a freeway/interstate is 45 mph. so upwards of 10 mph too low. Just because you meet the minimum manufacture tow specs, does not mean you will not get a ticket! you may be illegal per local laws.
Having spec'd multiple trucks for multiple uses, along with other machinery etc, one learns, that factory ratings may be a good or bad thing to follow! How you personally need things to operate and where, you may get away with using something over manufactures ratings, then again, you may have to use something at 50% of the ratings, and still destroy the unit WELL before it should be worn out etc.
Marty
Marty
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 24, 2026
